Old 05-14-2008, 07:00 PM
I've modified the original mirror sample script to support stereo. The main differences are that a render node must be created for each eye. Also, I had to increase the clip plane scale factor to remove the clipping issues. Let me know if this works:
viz.go(viz.STEREO)
REFLECT_MASK = viz.LAST_MASK << 1
def addMirror(mirror,mat=None):
	#If mirror matrix is not specifed, get matrix of mirror object
	if mat is None:
		mat = mirror.getMatrix()
	#Position of mirror
	pos = viz.Vector(mat.getPosition())
	#Direction mirror is pointing
	dir = viz.Vector(mat.getForward())
	dir.normalize()
	#Quaternion rotation of mirror
	quat = mat.getQuat()
	for eye in (viz.RENDER_LEFT,viz.RENDER_RIGHT):
		#Create render texture
		tex = viz.addRenderTexture()
		#Create render node for rendering reflection
		lens = viz.addRenderNode(size=[1024,1024])
		lens.setCullMask(REFLECT_MASK)
		lens.attachTexture(tex)
		lens.setInheritView(True,viz.POST_MULT)
		lens.disable(viz.CULL_FACE,op=viz.OP_SET_OVERRIDE)
		lens.disable(eye)
		#Setup reflection matrix
		rot = viz.Matrix.quat(quat)
		invRot = rot.inverse()
		lens.setMatrix(viz.Matrix.translate(-pos)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
		#Setup reflection clip plane
		s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
		plane = vizmat.Plane(pos=pos,normal=dir)
		dist = plane.distance([0,0,0])
		lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.1])
		#Project reflection texture onto mirror
		mirror.texture(tex)
		mirror.texGen(viz.TEXGEN_PROJECT_EYE)
#Add gallery environment
#Use existing painting as mirror and specify the matrix
mirror = gallery.getChild('art04-FACES')
m = viz.Matrix()
m.setPosition(mirror.getPosition(viz.ABS_GLOBAL))
m.setEuler(180,0,0)
#Apply mirror settings to mirror object
addMirror(mirror,m)
#Increase ambient lighting
viz.MainView.getHeadLight().ambient(1,1,1)
#Create a self avatar
avatar = viz.add('vcc_female.cfg')
#Link avatar body to viewpoint
avatarLink = viz.link(viz.MainView,avatar)
avatarLink.setPos([None,0,None]) #Keep avatar on floor
avatarLink.setEuler([None,0,0]) #Only update avatar yaw
avatar.setMask(viz.LEFT_MASK|viz.RIGHT_MASK,mode=viz.MASK_REMOVE) #Only draw avatar in mirror
#Link avatar head to viewpoint
head = avatar.getBone('Bip01 Head')
head.lock()
viz.link(viz.MainView,head,mask=viz.LINK_ORI)
