Old 05-10-2008, 09:13 PM
k_iwan k_iwan is offline
Red face Solved~!
I do apologise for making you running around in a circle. I did not explain the script fully. I tried to post the full code, but this forum refused it, being too lengthy. What I posted previously was a module of a bigger simulation program. You need to add viz.go() as well at the end of the program.
I do apologise.... T_T
You may use these following these commands (in the terminal window) to make them run...
controlAction()
stiltsAction(), and
stumpsAction()
..to make them run.
I just found the solution. I increased the spacing between the movement points and it works just fine. Apparently, my spacing between points were too small. I Increased the spacing and it works really well.
Thank you.
Kind Regards,
Iwan
