Old 05-08-2008, 07:16 PM
I really don't see how using the slerp command could disable position tracking. There is probably something wrong with your script, but I can't tell without seeing your code.
The vizppt.dls plugin is for connecting to the WorldViz PPT optical tracking device. If you are not using that device then you can remove remove the plugin from your script.
