Old 05-08-2008, 04:40 PM
The shadow projector can only cover a finite area. You could increase the size of the area, but this means your shadows won't be as smooth. Another option would be to have the shadow module follow the x,z position of the avatar. If your avatar is the only object that casts shadows then this is the best solution. Your shadows will always be sharp and your avatar will be able to walk all around your environment.
