Old 05-08-2008, 09:41 AM
PPT 2.0 would intentionally not render the camera images and certain other UI elements while talking. That behavior is normal. However, it should still draw the marker trails in the center grid. If that is being updated then I believe you are seeing the same problem I did. As I said I was unable to find the cause of the problem and haven't experienced it again. Have you tried restarting the PPT computer?
