Thanks for the reply.
What's Switch node? Is it a concept in Vizard or Maya?
I found that if I export the model to obj file, at least the polygon surface works fine, but all nurbs surfaces lost texture. So I'm going to convert all nurbs surfaces into polygon. Does that mean obj file works better than wrl file in Vizard?
