Old 03-23-2004, 02:50 PM
I'm pretty sure this means that your graphics card is crashing. It only happens with ATI cards. There should be an option in your graphics card settings to turn VPU recover off. Right click on the desktop and click Properties, then select the Settings tab, then click Advanced, then select the VPU Recover tab and disable VPU recover. I'm not sure if this will help, but it's worth a try. Let me know if you still experience this problem. Good luck!
