Old 04-17-2008, 03:33 PM
You can enabled viewpoint collision detection by using the following code:
viz.collision(1)
If you don't want the viewpoint to collide with the blueglass, then add the following line as well:
blueglass.disable(viz.INTERSECTION)
Also, I noticed that you set the eyeheight to 10000 in the script stage settings. You should set it to a smaller value like 1.8.
