Old 04-07-2008, 11:16 AM
The documentation for the Intersense plugin describes all the available commands (http://www.worldviz.com/vizhelp/Old_...se_Plug-In.htm).
The Intersense driver will automatically load a configuration file when a tracker connection is first opened. Here is the description from the InterSense API documention:
When a tracker is first opened, library automatically looks for a configuration file in current directory of the application. File name convention is isenseX.ini where X is a number, starting at 1, identifying one tracking system in the order of initialization.
The InterSense API has a function to send a configuration file to a tracker and another function to send a script to a tracker. I'm not sure what the difference between their configuration file and script is. Does the configuration file support your needs?
