Old 04-05-2008, 03:14 PM
wouters wouters is offline
Intersense Script
I am using using an Intersense tracker to provide head tracking data to Vizard. Currently, the tracker and Vizard interface works correctly once the tracker has been configured. Unfortunately, in order to configure the tracker I need to send a script to the tracker before it will send back correct data. I can do this manually before I run Vizard, but I am wondering if there is a way to automatically send a configuration script to the tracker using Vizard.
Also, how do you figure out what the different commands are for your tracker in the sensor.command() function?
Thanks for your help!
Leah
