Old 04-02-2008, 07:57 AM
atuin atuin is offline
Installation fails for 3ds max 2008
I tried to install the Vizard 3.0 - Cal3D Exporter for 3ds Max 2008, german
The setup doesn't recognize the 3ds-istallation, it is a german version, using a license server.
I am using Windows XP pro, german, 32bit, SP2.
In the registry are following entries:
HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/MAX-1_407
HKEY_LOCAL_MACHINE/SOFTWARE/Autodesk/3dsMax/10.0/ObjectDBX
Is there a way to install the plugin manually?
