There is no easy solution to this. One method would be to save the initial location of the head/hand/feet when you perform a reset. Afterward, every frame compare the new PPT marker positions to the previous head/hand/feet positions. The marker that is closest to the previous head position will be the head position for the new frame, and so on for the arm/legs. However, this method will break down if you bring the markers close together, or if a marker becomes occluded for an extended amount of time.
