Old 03-12-2008, 04:48 PM
If you are using 3dsmax then I highly recommend you use our max exporter which is freely available on our downloads page. It will export models to Vizards native format. You can choose between the text format (.osg) or binary format (.ive). The binary format loads very quickly and embeds all texture data inside it. The exporter also has an option to compress textures, which further reduces the size and loading time of the ive file.
