Old 03-11-2008, 07:15 PM
RedSpikeyThing RedSpikeyThing is offline
Originally Posted by farshizzo View Post
The SDK for dle plugins has not been released yet. Either way, extension objects receive the same type of command data as normal sensors, so I'm not sure how much it will help you. What kind of data are you trying to pass to your plugin?
hmmm I was under the impression that DLE's could have different constructors than DLS's. I'm trying to make a sensor that generates its data by merging two other sensors. Ideally it would just be a matter of passing the two sensors as parameters to the constructor. My other idea was more of a hack....cast the memory address of the sensor into a float and pass it as a command argument, where the C++ part casts it back into a memory address. I don't know if this will work, but it seems feasible.
