Example code for VizCave
Hi everybody,
I intend to create dynamic off-axis projections on a table-top 3D display and understand that the vizcave object provides all needed functionality for this. Unfortunately I do not get it to work. In particular when using manual update of the head position, I get unexpected results. I did not find some example code on the web or in this forum. Below is my simple beginner code to explore the vizcave functionality. Any pointers?
thanks
stefs
import viztracker
import vizcave
c0 = -2,3,0
c1 = 2,3,0
c2 = 2,0,0
c3 = -2,0,0
vp = -1, 1.8, -6
track = viztracker.add()
track.setPosition(vp)
cave = vizcave.Cave()
FrontWall = vizcave.Wall(upperLeft=c0,upperRight=c1,lowerLeft= c3,lowerRight=c2,name='Front Wall' )
cave.addWall(FrontWall, mask =None, window = viz.MainWindow)
def mytimer(num):
global cave
tposition = track.getPosition()
print tposition
cave.update(pos = tposition)
def drawWall():
viz.startlayer(viz.LINE_STRIP)
viz.vertex(c0)
viz.vertex(c1)
viz.vertex(c2)
viz.vertex(c3)
viz.vertex(c0)
viz.vertexcolor(1,1,0.1)
viz.startlayer(viz.LINES)
viz.vertex(c0)
viz.vertex(vp)
viz.vertex(c1)
viz.vertex(vp)
viz.vertex(c2)
viz.vertex(vp)
viz.vertex(c3)
viz.vertex(vp)
wall_frame = viz.endlayer()
viz.add('tut_ground.wrl')
mini = viz.add("mini.osgx")
mini.translate(0,1,-1)
mini.setScale(0.5, 0.5, 0.5)
mini.add(vizact.spin(0,1,0,15))
drawWall()
