Thread: vizact.fall
Old 03-03-2008, 09:09 PM
erchrastil erchrastil is offline
are there additional tags to indicate that the code is starting and ending? they are not clearly marked in any of the message options.
import time
import math
import random
import winsound
viz.go(viz.STEREO | viz.FULLSCREEN)
light1 = viz.addLight() #Add an overhead light
light1.setEuler(0,90,0)
## Prompt for the participant's identification number - generally keep this uncommented! ##
keyControl = viz.input('Using Tracker? 1 = Yes, 2 = No')
#subject = viz.input('What is the participant number?')
if keyControl == 1:
    eyeohd = viz.input('What is the participants IOD?')
viz.fov(43,1.395) #Cybermind specs
##Rename the main view ##
view = viz.MainView
#Link viewpoint with tracker, initialize boresite
if keyControl == 1: #If you're using the tracker
    headTrack = viz.addSensor('intersense')#Ignore documentation stating you need "intersense.dls" - this is correct
    linkedTracker = viz.link(headTrack, view) #Link the sensor to the view.
    linkedTracker.preTrans([0,-.15,.14]) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
    # viz.link(headTrack, view) #Link the sensor to the view.
    viz.eyeheight(0.0)
    view.translate(0,-.19,.14) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
    viz.ipd(eyeohd/100.0)
#Initialize parameters for keyboard control
MOVE_SPEED = 1.3 #m/s
TURN_SPEED = 60 #deg/s
#NOTE: Default eye height for keyboard control is 6', doesn't affect tracked viewpoint
viz.phys.enable() # Enable physics
viz.MainView.gravity (0)
#This turns mouse control of view and mouse pointer off - very disconcerting for subjects!
# Generally keep both viz.OFF, unless you have a specific need.
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
def masterLoop(num):
    global Risen
    fallAction = vizact.fall(-28.18)
    riseAction = vizact.fall(1.82)
    if view.getPosition(mode=viz.ABS_GLOBAL)[0] > -1 and view.getPosition(mode=viz.ABS_GLOBAL)[0] < 1:
        view.add(fallAction)
        Risen = False
    if view.getPosition(mode=viz.ABS_GLOBAL)[2] > 5.375:
        Risen = False
    elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < 4.625 and view.getPosition(mode=viz.ABS_GLOBAL)[2] > -1.625:
        Risen = False
    elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < -2.375:
        Risen = False
        view.add(riseAction)
        Risen = False
        print 'back up'
    elif (view.getPosition(mode=viz.ABS_GLOBAL)[0] < -1 or view.getPosition(mode=viz.ABS_GLOBAL)[0] > 1) and Risen == False:
        Risen = True
        print 'normal view'
    ###### KEYBOARD CONTROL MODULE - DON'T TOUCH ######
    if keyControl == 2: #If you're using the keyboard; defined at top
        if viz.iskeydown(viz.KEY_UP): #If the up key is depressed
            view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_OR I) # Move view to z coordinate specified by speed*elapsed time
        elif viz.iskeydown(viz.KEY_DOWN): #And so on and so forth
            view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
        if viz.iskeydown(viz.KEY_RIGHT):
            view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BOD Y_ORI,viz.RELATIVE_WORLD)
        elif viz.iskeydown(viz.KEY_LEFT):
            view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE _WORLD)
viz.callback(viz.TIMER_EVENT,masterLoop)
#This starts the timer. First value (0) is a timer identifier, second (1/60) is the refresh rate, third (viz.FOREVER) is how long it lasts
viz.starttimer(0,1/60.0,viz.FOREVER)
