Old 03-03-2008, 05:34 AM
Dave Dave is offline
Mohammed - brilliant, thanks for that. Works a treat - can now run the model smoothly in stereo using a quadro fx3700 with the 169.39 driver. Interestingly this works when you run labtool and have toggle left and right but, counter-intuitively (to me anyway) set the Force 3D mode to 2D! You also don't seem to need to leave labtool running - just start up, set Force 3D mode to 2D, close it down and then you can open the original z800 software utility (which has a couple of settings that I cannot see in labtool) - the left/right toggling continues to work - what's that all about? Anyway - thanks again.
