Thread: vizact.fall
Old 03-01-2008, 12:03 PM
erchrastil erchrastil is offline
sorry, i'm new to this format so i thought it would preserve the tabs that were in place. here's the code again:
import time
import math
import random
import winsound
ground = viz.add('Models/ground_2m.ive')
pit = viz.add('Models/ground_pit_new.ive')
viz.go(viz.STEREO | viz.FULLSCREEN)
light1 = viz.addLight() #Add an overhead light
light1.setEuler(0,90,0)
## Prompt for the participant's identification number - generally keep this uncommented! ##
keyControl = viz.input('Using Tracker? 1 = Yes, 2 = No')
#subject = viz.input('What is the participant number?')
if keyControl == 1:
eyeohd = viz.input('What is the participants IOD?')
viz.fov(43,1.395) #Cybermind specs
##Rename the main view ##
view = viz.MainView
#Link viewpoint with tracker, initialize boresite
if keyControl == 1: #If you're using the tracker
headTrack = viz.addSensor('intersense')#Ignore documentation stating you need "intersense.dls" - this is correct
linkedTracker = viz.link(headTrack, view) #Link the sensor to the view.
linkedTracker.preTrans([0,-.15,.14]) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
# viz.link(headTrack, view) #Link the sensor to the view.
viz.eyeheight(0.0)
view.translate(0,-.19,.14) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
viz.ipd(eyeohd/100.0)
#Initialize parameters for keyboard control
MOVE_SPEED = 1.3 #m/s
TURN_SPEED = 60 #deg/s
#NOTE: Default eye height for keyboard control is 6', doesn't affect tracked viewpoint
viz.phys.enable() # Enable physics
viz.MainView.gravity (0)
#This turns mouse control of view and mouse pointer off - very disconcerting for subjects!
# Generally keep both viz.OFF, unless you have a specific need.
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
def masterLoop(num):
global Risen
fallAction = vizact.fall(-28.18)
riseAction = vizact.fall(1.82)
if view.getPosition(mode=viz.ABS_GLOBAL)[0] > -1 and view.getPosition(mode=viz.ABS_GLOBAL)[0] < 1:
view.add(fallAction)
Risen = False
if view.getPosition(mode=viz.ABS_GLOBAL)[2] > 5.375:
Risen = False
elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < 4.625 and view.getPosition(mode=viz.ABS_GLOBAL)[2] > -1.625:
Risen = False
elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < -2.375:
Risen = False
view.add(riseAction)
Risen = False
print 'back up'
elif (view.getPosition(mode=viz.ABS_GLOBAL)[0] < -1 or view.getPosition(mode=viz.ABS_GLOBAL)[0] > 1) and Risen == False:
Risen = True
print 'normal view'
###### KEYBOARD CONTROL MODULE - DON'T TOUCH ######
if keyControl == 2: #If you're using the keyboard; defined at top
if viz.iskeydown(viz.KEY_UP): #If the up key is depressed
view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_OR I) # Move view to z coordinate specified by speed*elapsed time
elif viz.iskeydown(viz.KEY_DOWN): #And so on and so forth
view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
if viz.iskeydown(viz.KEY_RIGHT):
view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BOD Y_ORI,viz.RELATIVE_WORLD)
elif viz.iskeydown(viz.KEY_LEFT):
view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE _WORLD)
viz.callback(viz.TIMER_EVENT,masterLoop)
#This starts the timer. First value (0) is a timer identifier, second (1/60) is the refresh rate, third (viz.FOREVER) is how long it lasts
viz.starttimer(0,1/60.0,viz.FOREVER)
