Old 02-25-2008, 12:12 PM
theuberk theuberk is offline
Strange Rendering Lag Spikes
I seem to be having some strange lag spikes when running my simulation where the frame rate will drop down to and below 30fps. It's strange because I know the computer I'm using can handle the graphics processing (as the frame rate is usually at least 60fps) and most of the time when I'm experiencing these frame rate drops, simply pressing F4 to show the fps will fix the problem. I've turned off all data collection, shadows, and tried almost everything I could think of to fix the problem. This makes me believe that it must be something at a lower level. I do have custom events refreshing each update, but if these events were the problem, I'd think that the low frame rate would be constant..
Any ideas of what the problem might be?
