  #15
Old 02-20-2008, 04:13 AM
m7ossny m7ossny is offline
Cool We found a driverless solution for this problem on Quadro 4600 and 8600 GT
We had the same problem with 4600 Quadro, and 8600 GT. Same symptoms, the stereo is not working, messed up drivers, projecting the shuttering exactly to both eyes, ... .
If you are as desperate as I am, there is a solution. Forget about the stereo driver. If you have it just disable stereo at all. Download a 3dvisor's utility called labtool (http://www.3dvisor.com/support.php). It forces the 3d mode to the emagin box. We tried it with 162.15/18, and the monitor was daisychained to the emagin box and it worked.
Regards. Mohammed Hossny.
