Old 02-19-2008, 03:28 PM
Technically, your code should not work. I think the reason it works with IDLE is that IDLE runs the script in its embedded interpreter, which does not exit until the GUI is closed. If you ran the script directly from the command line, my guess would be that it would have the same problem as Vizard.
