Old 02-12-2008, 03:06 PM
The UpdateSensor function is called once per frame, regardless of how many instances of your sensors have been created. You should store each sensor pointer in a global vector during initialization, then iterate through them in the UpdateSensor function. Here is some pseudo code that should explain the general idea:
typedef struct {
	VRUTSensorObj*		instance;
	SOME_OBJECT_HANDLE	handle;
} MySensor;
std::vector< MySensor > m_sensors;
void InitializeSensor(void *sensor)
	//Create internal sensor object
	MySensor ms;
	ms.instance = (VRUTSensorObj *)sensor);
	ms.handle = CREATE_OBJECT_HANDLE;
	//Save sensor number in user field
	ms.instance->user[0] = m_sensors.size();
	//Set data size
	ms.instance->dataSize = 7;
	//Notify successfull initialization
	ms.instance->status = TRUE;
	//Save object in global array
	m_sensors.push_back(ms);
void UpdateSensor(void *sensor)
	//Update 'data' field of all sensors
	for(unsigned int i = 0; i < m_sensors.size(); ++i) {
		GET_OBJECT_DATA(m_sensors[i].handle,m_sensors[i].instance->data);
Let me know if anything is unclear.
