I have tested the Wiimote plugin using a Kensington Bluetooth 2.0 USB adapter with the WIDCOMM drivers and they work very well. I haven't tried with any other hardware, so there could be some issues with it.
The on-screen arrow is based on the IR data, which requires the IR sensor bar. You will need to make sure there are no other IR sources in the room as well. Is the inertial/orientation data responsive?
