Old 02-01-2008, 08:38 AM
Dave Dave is offline
Further news - I have still had no joy with the Quadro FX1700 and stereo using the QUAD_BUFFER command and an Emagin z800. Our supplier has talked to NVidia - they think it is a problem with the driver not syncing properly with the z800 - they did send a beta driver 169.19 that they said would solve the problem but this didn't work either. So I think I will have to move to a different Quadro board and driver hat is known to work with the z800 - so here is the question. Has anyone out there actually successfully used an Emagin z800 with a Quadro FX board and a Vizard routine invoking the QUAD_BUFFER command to give stereo in the HMD. If so I would be very grateful if you could let me know which Quadro FX board(s) you used and which driver - at least then I can use something that is known to definitely work. Thanks in anticipation.
