Old 01-30-2008, 02:00 PM
Strange Wii Mote error...
I recently started working with the Wii mote with Vizard. However, after a windows XP computer failure I found the code no longer worked.
While I was running code my system locked up and crashed.
Now when I try to use even the simplest wiimote compatible code, I get the following error:
File "C:\Program Files\WorldViz\Vizard30/python\vizact.py", line 2738, in __ontimer
val = event.call()
File "C:\Program Files\WorldViz\Vizard30/python\vizact.py", line 2564, in _callStatic
return self.func(*self.args,**self.kwargs)
File "TestStand_V_2_0_wiiMite.py", line 76, in UpdatePointer
x1,y1 = mote1.posIR
TypeError: unpack non-sequence
It is not code dependent, since even if I copy and paste the code directly from your example it still gives me the same thing.
Any ideas what this might be?
I uninstalled Vizard and upgraded to the new one for Q1 of 2008 and still have this error. Could it be a Bluetooth problem and maybe I need a reinstall there?
George D. Lecakes Jr.
