Old 01-29-2008, 02:23 AM
mspusch mspusch is offline
make sure you are really feeding the z800 HMD a 600x800 resolution and 60Hz frame sequential.
this is the most common mistake I have seen. the best is if you switch you computer to 600x800 output and connect a monitor BEHIND the Z800 HMD, i.e. route the VGA signal thru the HMD. do NOT use the dual out from your graphics card.
now go on the properties and make sure it's 600x800 and 60Hz, and shows up on the monitor as frame sequential (i.e. flickering).
if this is the case and it still does not work on your Z800, you should probably contact eMagins' support.
but I'll place a bet that there is something wrong with your output which is why it's not working currently.
good luck!
