Old 01-22-2008, 10:59 AM
mspusch mspusch is offline
it's not fully predictable what will work and what not, it's very similar as if you are planning to use this computer for games like halflife etc. -- but most likely Vizard will run 100%fine even on the version without the nVidia card with just the intel onboard graphics.
and as you say, if there is a performance issue, you can always reduce the window size.
i had a toshiba satellite laptop from 5 years ago for a long time, and it worked OK with vizard as long as the texture memory was not exceeded and I was running in a very small window.
we have Vizard running on several computers here at the office with Intel based onboard graphics, and it tends to run 100%fine on the newer ones of those onboard graphics units.
so you are probably OK with the non-nvidia option, however, it's not 100% sure that everything works ...
