Old 01-15-2008, 11:15 AM
Here is a sample script that shows how to create an array of objects:
#Example code for creating arrays
balls = []
for x in range(10):
	#Create a ball and set its position
	ball = viz.add('ball.wrl')
	ball.setPosition(0,0,x)
	#Append ball object to array
	balls.append(ball)
#Example code for using arrays
print balls
print len(balls)
for b in balls:
	print b.getPosition()
When you add a file, Vizard will first check if the path exists relative to the script directory. If it does not exist, then it will look for the file in the resource path.
