Old 01-11-2008, 10:26 AM
Atul Thakur Atul Thakur is offline
Originally Posted by farshizzo View Post
I'm not sure why the position data is not being updated in Vizard. I tested it out here and it works fine. Are you sure the switches on your flock of birds device is setup correctly?
I have set up dipswitch setting to be
1 - down
2 - up
3 - down
4 - up
5 - up
6 - up
7 - up
8 - up
following your suggestion on http://www.worldviz.com/forum/showthread.php?t=1293
However, I want to share an observation that the trackd daemon doesn't identify the sensors in this configuration of dipswitch. The trackd daemon runs properly when I set the dipswitch to be
1 - down
2 - up
3 - down
4 - up
5 - up
6 - up
7 - down
8 - up
however in this case vizard doesn't identify the fob and gives error like "not found on com1".
I am puzzled as what settings for dipswitch should I keep
Thanks and regards,
-Atul
