Old 01-09-2008, 07:42 AM
theuberk theuberk is offline
inheritence question
I'm trying to make custom class called car a subclass of the VizNode class, but I'm having a few problems. Here is the main part of my constructor for the car class:
class Car(viz.VizNode):
	def __init__(self, direction = "right", id = sys.carID):
		randomCar = random.randint(1,14)
		if (randomCar == 10):
			randomCar += 1
		if (randomCar > 10):
			self.tempCar = viz.add( "cars\car_" + str(randomCar) + ".ive" )
			self.tempCar = viz.add( "cars\car_0" + str(randomCar) + ".ive" )
		viz.VizNode.__init__( self, self.tempCar.id )
The problem lies in that I cannot seem to manipulate any of the fields present in the VizNode class from outside the car class. For example:
If I add the following code to the car constructor:
self.tempCar.collideBox()
self.tempCar.setVelocity([10,0,0])
the car will fall and move along the x-axis at 10units/s
however, if I type the following code outside of the car class:
viz.phys.enable()
car = Car()
car.collideBox()
car.setVelocity([100,0,0])
I get the following error:
Cannot collideBox with invalid bounding box
collideBox is not the only method that does not work. I've also tried methods like car.setPosition(10,0,0) which also does not do anything.
Any ideas?
