The sample program cbird.exe is running fine. I mean, when i move the wanda, the coordinates change in case of cbird.exe <not yet calibrated it though>
However, in case of Vizard the coordinates do not change in one run.
But when I run the script in Vizard again after moving the wanda, the position is changed. This indicates that apparently there is no hardware problem.
I checked the Baud rate and dipswitch setting. As per the Ascension manual the settings are right.
thanks,
-Atul
