Old 11-29-2007, 11:17 AM
Elittdogg Elittdogg is offline
Hopefully you can run it now:
import math
import whrandom
import string
viz.go(viz.PROMPT)
# Get subject number from prompt box
promptMesg = viz.get(viz.INITMESG)
if promptMesg == "":
	Subnum 	= 999
	Trial	= 100
	text = string.split(promptMesg)
	Subnum = int(text[0])
	Trial = int(text[1])
print "Subnum =", Subnum
print "Trial =", Trial
PORT_FOB = 1
NUM_FOB = 6
NUM_DOTS = 900
RADIUS = .5
DATA = 2
AMPLITUDE = .05
X1 = 0
X2 = 64
MAX_SAMPLES = 60.0 * 30.0
SAMPLE_RATE = 1.0 / 30.0
samples = 0
viz.startlayer(viz.POINTS)
viz.vertexcolor(1,1,1)
viz.pointsize(4)
for i in range(0, NUM_DOTS):
  x = whrandom.random() - 0.5
  y = whrandom.random() - 0.5
  z = whrandom.random() - 0.5
  length = math.sqrt(x*x + y*y + z*z)
  x = x / length * RADIUS
  y = y / length * RADIUS
  z = z / length * RADIUS
  viz.vertex(x, y, z)
sphere = viz.endlayer()
sphere.translate(0,1.8,.2)
flock1 = viz.add('flockofbirds.dls')
#flock2 = viz.add('flockofbirds.dls')
#flock3 = viz.add('flockofbirds.dls')
#flock4 = viz.add('flockofbirds.dls')
flock1.command(6)
#flock2.command(6)
#flock3.command(6)
#flock4.command(6)
tracking_data = open('openloopsine_complex/headdata_'+ str(Subnum) + " " + str(Trial) + '.txt', 'a')
#tracking_data2 = open('openloopsine_complex/hipdata_'+ str(Subnum) + " " + str(Trial) + '.txt', 'a')
#tracking_data3 = open('openloopsine_complex/kneedata_'+ str(Subnum) + " " + str(Trial) + '.txt', 'a')
#tracking_data4 = open('openloopsine_complex/ankledata_'+ str(Subnum) + " " + str(Trial) + '.txt', 'a')
def mytimer(num):
	if num == 0:
		global AMPLITUDE, TOTALCYCLES, X1, X2, samples
		data1 = flock1.get()
		HEADLAT = data1[0]
		HEADVERT = data1[1]
		HEADAP = data1[2]
		HEADYAW = data1[3]
		HEADPITCH = data1[4]
		HEADROLL = data1[5]
		head_data = str(Subnum) + '\t' + str(Trial) + '\t' + str(HEADAP) + '\t' +str(HEADLAT) + '\t' +str(HEADVERT) + '\t' +str(HEADYAW) + '\t' +str(HEADPITCH) + '\t' +str(HEADROLL) +'\n'
		tracking_data.write(head_data)
	if num == 4:
		xmove = AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(3.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(1.75*(math.pi/180)*X1) + AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(3*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1)+ AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(1.75*(math.pi/180)*X1)
		X1 = X1 + 1
#		print xmove
		sphere.translate(0,1.8,.2+.3*xmove, viz.ABSOLUTE)
	if num == 3:
		viz.quit()
	if num == 1:
		#TODO: Process sample
		#Increment samples
		samples += 1
		if samples < MAX_SAMPLES:
			viz.starttimer(1,SAMPLE_RATE)
			print 'Finished collecting samples'
def onkeydown(key):
	if key == ' ':
		viz.starttimer(0,(1.0/30.0), viz.FOREVER)
		#Clear samples and start timer
		samples = 0
		MAX_SAMPLES = 60 * 30
		viz.starttimer(4,(1.0/30.0),viz.FOREVER)
