Old 11-28-2007, 11:50 AM
Computers are not %100 perfect when it comes to timing, however you should be able to achieve a reliable sample rate of 30Hz. I did some tests here and I got the same number of samples every time. I don't know why you would get such varying values. Is your simulation running at 60Hz? Do you have a simple script that reproduces your results?
