I think the problem in this case is that you need to convert the repeat count to an integer when passing it to the vizact.sequence command. Try the following instead:
MoveRoom = vizact.sequence(vizact.move(0,0,(0.5/time),time), vizact.move(0,0,(-0.5/time),time), int(30/time))
