Thanks for the files. The problem seems to be that both your meshes are exactly the same. Each mesh contains the entire avatar, including body and head. If you comment out one of the mesh files in your cfg file, the entire avatar will still appear. You probably have an incorrect version of the complete character. The correct version will have a separate mesh file for the head and another mesh file for the rest of the body.
