Thread
Joystick Navigation
8
10-23-2007, 11:42 AM
farshizzo
You've programmed the script to move the viewpoint when the joystick is moved. If you want the viewpoint to look up/down when the joystick is moved, then use the viewpoint.rotate() command instead of the viewpoint.move() command.
farshizzo
View Public Profile
Find all posts by farshizzo
