Old 10-22-2007, 05:01 PM
Hi Tolek,
The problem you are having sounds like one I saw last July where somehow the multi/sub-object material got corrupt, and for some reason typing names for each material ID fixed the problem. That post can be found here, complete with pictures.
If that doesn't work, I'd like you to follow the directions in this post so we can determine if it is a problem with Vizard reading the files or a problem with Max exporting the files.
