Old 01-30-2004, 10:58 AM
If you want to snap the viewpoint to a certain location when a key is pressed then you will use a KEYBOARD_EVENT. This is an event that is triggered whenever a key is pressed. Here is an example that will place the viewpoint at the position [1,2,3] and reset the orientation whenever the 's' key is pressed:
def mykey(key):
	if key == 's':
		viz.reset(viz.HEAD_ORI|viz.BODY_ORI|viz.HEAD_POS)
		viz.translate(viz.HEAD_POS,1,2,3)
Good luck!
