The flock of birds needs to be connected to your computer in order to communicate. The port number refers to the serial port number that the flock of birds is connected to your computer on. If your motherboard has a built-in serial port, then the port is usually 1. If you are using either a USB to serial convertor or an addon PCI serial card, then you need to check what the assigned port number is in your computers device manager.
