Old 01-28-2004, 05:34 PM
To get information about the viewer use the viz.get() command. Take a look in the command reference of the documentation for a more detailed description. Here's an example:
#Get the head position
pos = viz.get(viz.HEAD_POS)
#Get the yaw of the viewer
#Note: yaw refers to rotation about the Y-axis
yaw = viz.get(viz.VIEW_YAW)
Take a look at the duckcourt example in the tutorial folder for using crosshairs. Here's the basic idea:
#Add a texture quad to the screen
crosshair = viz.add(viz.TEXQUAD,viz.SCREEN)
#Apply your crosshair texture to the quad
#Make sure you have an image file with transparency
crosshair.texture(viz.add('crosshair.png'))
#Turn off the mouse cursor
viz.cursor(0)
def mytimer(num):
	#Update the crosshair position
	crosshair.translate(viz.mousepos()+[0])
Good luck!
