Old 09-18-2007, 03:46 PM
Deltcho Deltcho is offline
The win98 instructions will work under winXP as well. Once you are done setting it up as it says, you must disable all other joysticks in the windows control panel.
After that, open up the intersense server and enable joystick control. Then you simply run Jmouse (which should already be installed) and start up Quake. Check your intersense installation directory for Jmouse (e.g. something like C:\InterSense\Programs).
I've attached the PDF with instructions in case you don't have it.
