Old 09-12-2007, 05:06 PM
You are referring to 2 different things. If you want the overall resolution of the graphics to be sharper, then you will need to set your monitor resolution to its maximum range. If it is already maxed out and you still want textures to appear sharper, then you must use higher resolution images for your textures.
