Old 08-31-2007, 12:47 PM
Here is some code that will manually apply tracking data to the viewpoint:
def mytimer(num):
	data = sensor.get()
	view.translate(data[0],data[1]+1,data[2])
	view.rotate(data[3],data[4],data[5])
viz.starttimer(0,0,viz.FOREVER)
If it still doesn't work, then you might have a problem with your hardware.
If you want to invert the left/right movement then negate the yaw component of the rotation data. So the above rotation command would look like the following:
view.rotate(-data[3],data[4],data[5])
