Old 08-17-2007, 03:49 PM
I tried your script but there were some errors with it. I fixed the errors and it works for me now. Can you try the following code:
#Changing the background color to SKYBLUE
viz.clearcolor(0.5,0.5,1)
#Defining the move and the turn speeds
MOVE_SPEED = 5
TURN_SPEED = 60
#Adding the objects to the world
car = viz.add('mini.osgx')
#Getting main viewpoint object
def mytimer(num):
    if viz.iskeydown(viz.KEY_UP):
        view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
    elif viz.iskeydown(viz.KEY_DOWN):
        view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
    if viz.iskeydown(viz.KEY_RIGHT):
        view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
    elif viz.iskeydown(viz.KEY_LEFT):
        view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
    updatecar()
def updatecar():
  car.translate(view.get(viz.HEAD_POS))
  car.rotate(view.get(viz.BODY_AXISANGLE))
  car.translate(0.35,-1.2,0.2,viz.RELATIVE_LOCAL)
#def updatecar():
#    car.translate(view.get())
#    car.rotate(view.getAxisAngle(viz.BODY_ORI))
#    car.translate(0.35,-1.2,0.2,viz.RELATIVE_LOCAL)
def mousemove(e):
    #euler = view.getEuler(viz.HEAD_ORI)
    euler = view.get(viz.HEAD_EULER)
    euler[0] += e.dx*0.1
    euler[1] += -e.dy*0.1
    euler[1] = viz.clamp(euler[1],-90.0,90.0)
    view.rotate(euler,viz.HEAD_ORI)
def mousedown(button):
        view.reset(viz.HEAD_ORI)
    elif button == viz.MOUSEBUTTON_RIGHT:
        view.reset(viz.BODY_ORI|viz.HEAD_POS)
        updatecar()
viz.callback(viz.MOUSE_MOVE_EVENT,mousemove)
viz.setMouseOverride()
viz.cursor(viz.OFF)
viz.callback(viz.MOUSEBUTTON_EVENT,mousedown)
viz.mouse(viz.OFF)
viz.restrictmouse(viz.ON)
