Thread: Cluster Help
Old 08-06-2007, 05:56 AM
videcuk videcuk is offline
Hi
The error on the master PC is printed out after around 15 seconds. The error on each of the clients follows ahortly after that.
We found an older thread on extending the client timeout using the 'vizcore.cfg' files and have extended the timeout on each of the clients to 100000 using 'viz.cluster.client.init_timeout = 100000' but still get the same errors.
When we put in the import socket etc in the interactive window as above, vizard returns the IP address (for example 134.220.14.241 for the PC named 'Image-Gen-1') of each of the clients immeadiately.
Thanks...
