Old 07-27-2007, 02:58 PM
theuberk theuberk is offline
Flock of birds extended range problem
I'm using an extended range flock of birds setup. The system is set up so the extended range unit (address 0) is attached to the host via a RS232 serial port and the extended range unit is then attached to the bird unit (address 1) that is receiving all the sensor data. The Extended range and bird units are connected via FBB. I checked the manual and realized that I need to send an "RS232 TO FBB" command to the extended range unit in order for the host to get the sensor data. Can this be accomplished in python? If so, how?
Robin
