Old 01-15-2004, 01:33 PM
Hi Karthi,
There are two ways of doing this and it depends on whether your avatar will be moving around or standing in the same place.
If your avatar will be standing in the same place then you can use hotspots. The following code creates a circular hotspot that is triggered when the head position comes within 1 meter from the position (POS_X,POS_Z):
POS_X = 3
POS_Z = 6
avatar = viz.add('female.cfg')
avatar.translate(POS_X,0,POS_Z)
DISTANCE = 1
ENTER = 1
EXIT = 2
def myhotspot(id,x,y,z):
	if id == ENTER:
		print 'entering reaction area'
		viz.starthotspot(EXIT,viz.CIRCLE_HOTSPOT_OUT,POS_X,POS_Z,DISTANCE)
	if id == EXIT:
		print 'leaving reaction area'
		viz.starthotspot(ENTER,viz.CIRCLE_HOTSPOT_IN,POS_X,POS_Z,DISTANCE)
viz.callback(viz.HOTSPOT_EVENT,myhotspot)
If you have multiple avatars then you can create multiple hotspot events for each avatar.
If your avatar is moving then you can create a timer loop that contantly checks whether the head position is inside the reaction area, like the following code:
import vizmat
avatar.translate(2,0,5)
avatar.outside = 1
DISTANCE = 1
def mytimer(num):
	headPos = viz.get(viz.HEAD_POS)
	headPos[1] = 0
	avatarPos = avatar.get(viz.POSITION)
	avatarPos[1] = 0
	distance = vizmat.Distance(headPos,avatarPos)
	if avatar.outside:
		if distance < DISTANCE:
			print 'entered reaction area'
			avatar.outside = 0
		if distance > DISTANCE:
			avatar.outside = 1
viz.starttimer(0,0.05,viz.FOREVER)
Good luck and let me know if you need anymore help
