Old 07-25-2007, 10:51 AM
The ideal position would be on the floor, however if you are attaching the sensor to the head and hands, then they might go out of range of the receiver. If you are noticing that the data is very jittery, then you might need to place the receiver on a table, so that it is closer to the sensors. If you do this, then you will need to offset the sensor data in your Vizard script to adjust for the new height.
Have you tested out the sensor range? What is the maximum acceptable distance the sensors can be from the receiver?
