Thread: 3d projector
Old 07-23-2007, 12:08 PM
mspusch mspusch is offline
hi, when the projector and your glasses are working correctly, you should see very obvious 3D, i.e. you should see depth in the way of stuff going into the screen/sticking out of the screen. if this is not the case, then there is something wrong still.
nVidia has a test-image in their drivers with a square in front of a green screen. when you start your 3D, you should very clearly see the square be in front of the green screen. is this the case for you?
when you look at the 3D projector output without glasses, it should look quite unfocussed/blurry, i.e. you should basically not be able to see anything well. is this the case?
