Old 07-21-2007, 12:46 PM
Originally Posted by theuberk View Post
Thank you so much! Everything works flawlessly now. How did you find out that the material names was the problem?
In this case, it was mostly process of elimination and a bit of luck. If that hadn't worked, I probably would have had to rebuild the entire material in another slot.
